2001 c32 wipers not working
Old Oct 27, 2011 | 12:37 PM
parksie c32's Avatar
C32 AMG
A quick search didn't reveal anything??
My wipers have just given up!!! the fuse is OK, does some knowledgeable fella have an idea as to which relay controls the wiper operation???
Couldn't have happened at a worst time ,we are getting some really heavy rain right now!
Any help at all gratefully received.
Old Oct 27, 2011 | 02:58 PM
alkrstev's Avatar
Silver 02 C32 & White 05 CLK500
Most likely is that you have a dead wiper motor. Do a quick search on google under "C32 wiper motor" and some websites will pop up. They usually go for around $130. It is not hard to replace and you can do it yourself. Just take off the plastic cover where the wipers are and you will see the motor. Good luck
Another thing I would try first is just disconnect the battery for about 20 minutes to see if there was a glitch or a short somewhere and it may fix it.
Old Oct 27, 2011 | 04:16 PM
C32 AMG
Update
Try the battery disconnect to no avail, but thanks for the tip any way.
also noticed that the screen wash is not working & no sound of a motor starting up??
the headlight flash works as does the main beam/ i recon the control stalk could be faulty??
Old Oct 27, 2011 | 04:23 PM
C32 AMG
Update
