Stupid Question, Setting The Clock?
CLS55
I have a C32 2003 that had the factory navigation. To the best of my knowledge, the clock was set though the factory nav unit. But, I have since removed the factory nav unit and replaced it with an after-market Pioneer system.
The clock is shown in the cluster, but how can I set it?
CLS55
I haven't yet, the place that installed my system was having a hard time finding a module that would work. So, the volume and next track / back track right now doesn't work.
CLS55
Also, do you know if the dealer could set the clock (like some special way hooking up the car lol)?
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Unfortunately the instrument clustor takes the time from the comand unit (navigation) when this option is fitted. What you will need to do is get the instument clustor recoded so that it's not looking for the comand unit and this will then allow you to change the time via the instrument clustor.
You will need access to a star diagnosis unit, change the varient coding in the EIS and instrument clustor to show comand not present. This will then re-enable the clock adjustment in the instrument clustor. Your model should be pre-scn coding so this is easy to change.
CLS55
After I unstall the PAC things to make the steering wheel controls work, that should also let me set the time in the cluster via the cluster settings?
