P0123 and no power when flooring
I have some problems with CEL coming on and going off every so often, and the car goes into limp mode if I floor it really quick. With the result being it takes around 20 sec to go 0-60 and even revving when in park is painfully slow.
Switching engine off and on again fixes the problem until I floor it again. If I gradually increase throttle, it doesn't happen, the car runs really strong if I'm a tiny bit more careful.
So I had my mechanic pull codes and they found P0123, which is the throttle position sensor (P0123 Throttle/Petal Position Sensor/Switch A Circuit High Input). He suggested to replace the fuel filter and do a fuel system cleaning ($300) which I said no to, because I feel it's alot of money to spend on something I have my doubts will fix the problem. So I just wanted to check with you guys, and hear if you have had this specific problem, and how you fixed it.
And who should I trust if my mechanic can't get it right?
