CLK55 AMG 18" rims/tires rubbing.
2002 C32 AMG
Hey guys, just purchased a set of CLK55 AMG 18" wheels. The 1 peice type 4's. The guy who sold it to me mounted the wrong tire size. Obviously I knew I would have problems, but the front tires don't even move. They are completely wedged under the spring perch. The tires are 245/45/18 all around. The rims at ET37/35 F/R and 7.5/8.5" F/R. The rears fit fine, although they are very close to the fender. Obviously, the rears should be lower profile. Should the rears be 245/40/18 or 255/35/18? I've seen both sizes being used, so just want to make sure what's OEM and what size will clear for sure. The fronts have me worried. Obviously if I run the 225/45/18 as opposed to the current 245/45/18 I will have better clearance, but will it be enough? Do I need spacers or to run a 225/40/18?
any help would be greatly appreciated. Thanks guys.
Bryan
Bryan
Got any links to deets on your other cars? As you can tell from my screenname, I'm an ex-Saab driver. V. cool that you have one of the few official Euro-spec E36 M3s in the country.
The stock rears on a C55 are 245/35/18s. I just ordered a set of 255/35/18s, there is about 1% difference in rolling diameter. 1010tires.com's tire size calculator is very useful, and recommends less than 2% difference.
PM or search member 'kent246', he has a lot of experience with wheel and tire fitment on the car. I believe he told me once that 245s up front won't work. This is on a C55 though, it'd be nice to compare a C32 to a C55/CLK side by side to check out if there is any additional fender clearance because of the CLK front end versus the regular 203 fenders.
I think Kent runs 235/40/18s up front, and 265/35/18s in the rear, stock height, but with SL55 wheels. I think that's probably quite aggressive already, and it would be even more so if lowered, then you're getting into needing fender rolling and such. I think your current square set up is probably too wide in the front to be comfortable, and too high in profile at the rear to keep the speedo within tolerances.
Yea, 45 series is definitely huge to be running up front and no wonder it hits the perch. It's all a tight fit even at the factory specs.
Stock is 225/40 and 245/35, but 255/35 fits better and is even stock on the CLK55. People have been known to squeeze in 235/40 and 265/35, but that's as tight as you can go.
2002 C32 AMG
Good stuff, looks like I'm going 225/40 and 255/35. Seems to be the same size for the BMW 335's. I'm going to go all out and get some Michelin Pilot Super sports ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
BTW, so according to the specs, are they indeed the clk55 wheels? ET 37/35 and 7.5/8.5? I'm just worried the front will have offset issues if they were maybe mounted on a different car (E55, S55, etc). I'm not sure if there were differences between them. My car is on the C55 suspension, but that shouldn't make a difference with spring perch/tire clearance.
Thanks for all the help guys.
bry
bry
1 Post
C55 AMG, 135i, 911 GT3, GLE43 AMG
On stock C55 rims (7.5x18 ET30 front, 8.5x18 ET34 rear), I use 225/40 in the front and 255/35 in the rear.
On CLK63 rims (8x18 ET34 front, 8.5x18 ET30 rear), I use 235/40 in the front and 255/35 in the rear.
Absolutely no problems on the street or on lapping days at a track. I'm on stock C55 suspension.
2002 C32 AMG
BTW, are you in ontario?
2002 C32 AMG
Can anyone confirm the part numbers? What I have is the following..
Front A2094014802 ET37 7.5x18
Rear A2034013902 ET34 8.5x18
My mistake, previously I indicated the rears were ET35 when infact they were ET34. According to what I found, the SLK55/CLK55 uses ET37/ET30 F/R and the C55 uses the setup I currently have, ET37/ET34. Is this correct?
PC Valkyrie listed the C55 stockers at 7.5x18 ET30 front, 8.5x18 ET34 rear, or was that a typo? I'm really confused now.
1 Post
2002 C32 AMG
So do I have a CLK55 front and C55 rear? Regardless, the fact that you run an ET34 front w/ a 235 width with no rubbing should mean that I would be fine with a 225 width and an ET37 correct? I would still like to find out exactly which car my rims came from, or if they are being mixed and matched.
thanks.
thanks.
1 Post
thanks.
thanks.
I'm in Edmonton, actually. Go Oilers!
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
I've got a set of early W209 CLK staggered AMG 17s for winter use. I can't recall the offset at the moment, but they are quite conservative, especially at the front. Looks dopey. Once ,y new rear tires arrive, I'll be back on the stock 18s. After that, once I finish counting pennies, I want to grab a set of 18" Forgestar F14s. This offset discussion will be useful, see how aggressive an offset the car can handle.
2005 C55, 2006 Ram 2500 MegaCab diesel, sold 2001 Dodge 2500 Cummins, sold 87 190e-16v, sold 97 e420
Bryan
Bryan
I have CLK55 rims on my car (on the inside it says A209....etc). Front is ET37 and Rear is ET30. C55 rims is ET30 front and ET34 rear. So technically, you want C55 fronts and CLK55 rears
I would love to have an extra quarter inch in my front wheels, they look too tucked in as they are now.
2002 C32 AMG
Hey guys, just a quick question. I'm not sure if anyone can answer this as it's specific to my setup. So I have front 225/40/18 w/ ET37. I also have a set of H&R 5mm wheel spacers installed. My question is if I go for the H&R steer perf coilovers, will my setup clear the pearches? I'm just looking for something a tad stiffer as I plan to do more track days now. Are the H&R coilovers a good choice for occasional track use? I realize not too many people attend lapping days on this forum, so I'm sure a lot of opinions will be from people who run them on the street. I'm mainly interested in track performance. I can get H&R's at a very good price, which is why I'm considering them over KW or Bilstein. I've run PSS9's and KW V2/V3's in the past, just never tried H&R.
thanks.
thanks.
thanks.
thanks.
2002 C32 AMG
The main reason I buy coiilovers is because the valving on the struts/shocks are valved properly for the springs that come with the kit. I'm not a big fan of mixing and matching springs/shocks unless I can get some linear springs and get the KONI's revalved. That's a bit too much work. Just looking for something a bit stiffer than my current C55 setup.
