Cm30 pump replacement, need drain the whole coolant system?
Everything, tools and CM30 pump were prepared. Just want to know if I can block the water hose immediately to replace the pump rather than drain the whole system?
Any advise?
something else, the cm30 has no plug on the end. i removed the broken pump and tore it apart removing the plug end from the end of the broken pump. theres a small capacitor on it i replced it with a new one and soldered the bosch plug onto the end of the cm30 and using heat shrink insulated the plug. now its plug and play
