C32 New 18" rims & SL55 intake - Car Feels Slower?
Old Jun 18, 2012 | 07:11 AM
link146's Avatar
'02 325 xi; '02 C32; '90 ZX; '08 CBR 6RR, '86 V45 Magna
If wheels and tires weight a few lbs more than before. - Im no physicist but you could theoretically gain considerably more rotational mass. Any engineers please weigh in.
Old Jun 19, 2012 | 03:21 AM
tw2's Avatar
tw2
I also am no physicist but heavier wheels and tires create a lot more rotational enertia which reduces acceleration, makes braking worse and doesn't improve traction or handling. Generally the stock wheels are the best for most cars. Any aesthetic wheel changes should weigh the same or less to not go backwards performance wise. The spread of weight from the centre outwards also has an effect. The best upgrade is better tyres.
Old Jun 19, 2012 | 03:44 AM
xxGenericSNxx's Avatar
99 ML430, 01 CLK55, 07 R63, 15 E63 Wagon
Larger diameter wheels will slow down acceleration and be worse for braking. The plus side is that you have a higher top speed.
Old Jun 19, 2012 | 05:47 AM
varoom's Avatar
C32 AMG
The car is still awesome though...
and it looks so good...
so pulley and tune is deff on the cards
Old Jun 19, 2012 | 03:01 PM
link146's Avatar
Increase top end or screw with ur speedo?
Old Jun 20, 2012 | 02:47 AM
tw2's Avatar
tw2
You will have a higher max speed only if it is limited by redline in top gear. Your speedo will read lower than the speed really is. None of this is a concern if the rolling diameter of the wheel is the same. If the tyres are lower profile on the larger wheel with approximately the same diameter then it will not make a difference to these two things.
