Intercooler pump plug
Old Jun 15, 2012 | 01:03 PM
loudandheard's Avatar
C32/C55 AMG
A few years ago I swapped my intercooler pump with a ford lightning pump and had to splice in a new plug. I must have thrown away the stock plug and I went to install a new Mercedes intercooler pump and noticed the plugs were different. So does anyone know where to get the factory plug or another solution?
Old Jun 15, 2012 | 01:13 PM
Wilsophia's Avatar
2002 W203 C32 AMG / 1997 Toyota Corolla AE110
I installed johnson cm30 pump, no plug, just cut and soldering. Directly.
Old Jun 15, 2012 | 03:06 PM
C32/C55 AMG
That's not a bad idea, but I suck at soldering and there's not a lot of room for mistake.
I went to the dealer and was able to order the plug for $13 and some change. I'll post the part number when I get it if anyone is interested.
Old Jun 15, 2012 | 04:46 PM
320 dreamer's Avatar
2003 porsche 996 turbo
do you mean the plug from the pump end or the wiring harness end? if its the latter do you have the part #?
Old Jun 15, 2012 | 05:44 PM
C32/C55 AMG
Yes, I'm talking about the plug at the end of the wiring harness. I'll post pics when I get it on Monday. Here are the part numbers:
Cable 011-545-01-28 price $4.22 qty 1
pin bu hd2c 011-545-01-28 $3.93 qty 2
Old Jun 15, 2012 | 09:25 PM
saer1one's Avatar
2002 c32 AMG 2012 c250 Coupe
HAHAH..!!! I did the same thing and also threw away the stock plug..
Thanks for the part numbers.. Will keep them until next time..
Old Jun 18, 2012 | 12:21 PM
C32/C55 AMG
Turns out it was the incorrect connector and part number. Still trying to figure out a solution. I may just solder the connections, but there's not a lot of room for error.
