Help - Driver window rolls up but not down
Old Jul 15, 2012 | 01:04 PM
SYZYGY's Avatar
C32, E93 M3
Exclamation Help - Driver window rolls up but not down
I've taken apart the panel and thought that I had a faulty driver motor as the window would no longer work one day. It was stuck in the closed position. I purchased a new window motor and installed it and the only direction the motor will turn is the up position. I've tried getting the motor to roll down, but it does not do so. I can rule out the regulator being jammed as I've tested the motor plugged in but not installed into the regulator. All the other windows work fine from the driver side controls.
What is going on?
Old Jul 15, 2012 | 09:10 PM
Saaboteur's Avatar
eclectic assortment of cars
Have you had the battery off? Pretty basic, but each time thy battery comes off you need to reset the window motors.
Old Jul 15, 2012 | 09:18 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Try the re-synch on the windows, if that doesn't work swap the motor from the driver side the passenger side this will allow you to determine if the motor is bad.
Old Jul 15, 2012 | 10:17 PM
W203Ramos's Avatar
'03C32 Obsidian Black, '76Toyota Celica GT TRD, '12R350 4matic Arctic White, '06 ML 350 arctic white
swap ur switches first.
Old Jul 16, 2012 | 09:44 PM
SYZYGY's Avatar
C32, E93 M3
I hear the relay clicking when I push on the window switch. The motor is fine, I already verified this in my first post. Battery has not been disconnected. I'm leaning toward a faulty control module, but if it's just a switch, that would be a lot cheaper.
Old Oct 18, 2012 | 04:28 PM
SYZYGY's Avatar
C32, E93 M3
bump. Can anyone give me the control module PN? I can't seem to find it.
