C55 coolant leak... help
Backstory though, I did have my radiator replaced by the dealership last week at a pretty low cost with warranty. I live in Northern VA and we went from about 20 degrees outside to 70 the next day. It was a pretty drastic change so I figure it could have wreaked havoc on my cooling system.
So do I need to fill/top off my transmission fluid or my coolant because of the radiator change?
Have u done the trans reset trick? That might fix the lazy shifts.
And I have not done the trans reset, did not know about it, are you referring to the ECU reset?
Its a tcu reset. Try it out its easy and really works.
