Kompressor weird sound. Need Help!
Hi guys,
I bought the Eurocharged Power Package I (ECU - Pulley - Tune - IC - IC30 Pump) and the package came with a new Bearing for the Kompressor. I installed everything in the Peruvian Mercedes dealership and after a while the kompressor started to sound like this (see video). http://youtu.be/5CL4aqgGlRs I complained to the dealership and they said that its not the BEARING that they "changed", that its a "internal kompressor bearing" that can not be replace without change the entire kompressor!?!?!? :crazy: I believe its the external Kompressor bearing (orange in the video) that everyones change but i have my doubts. Anyone heard about a "internal K bearing?" Please help! :bow: |
I think its the kompressor bearing, im going to change it again (i dont think they change it) i will let you know.:D
Any DIY about pressing out the bearing from the pulley? |
I changed the SC Pulley bearing for a new one...The weird sound continued...:smash:
After the installation i noticed that the clutch had a strange noise..is this normal? or the sound came from a loose pulley clutch? http://youtu.be/Ma6jkifm0TM |
This is not a good sound. You may need to rebuld yours. Most likely the coupler needs replacement. Maybe more.
I believe that the sound came from that loose clutch disc (attached to the SC pulley). I will take out the SC Pulley again and try to press the clutch disc attachment pins to keep it still.
Where can i buy a new pulley with the coupler? |
I just checked my clutch and it has no sideways play at all. I can sort of make that noise by pushing rearward on the rivet but that is probably the clutch faces mating at that point.
Is your power package a SC pulley or the crank pulley? |
Looks like someone fuked up your sc clutch during the install or did not put it back properly. It should not have any loose play in them.
I take the pulley with the clutch to a friend who owns a Clutch Service Workshop, he told me that the clamps of the disc were a little loose. So he used a machine that tight those clamps.
Now the plate clutch is really tight. I re-assembly the pulley and the sound is gone. :D and everything seems to be ok! :y Im going to try the car tomorrow because now its raining hard..so i will keep you guys updated! Thanks for the help! |
Problem Solved! :D
Did you have to take the clutch off? What kind of clutch service does your friend normally work on mine has the same noise.
Hi Juan,
We just adjusted the "CLUTCH PLATE CLAMPS" with a machine that its like a little press. Probably you can do the same with a small hammer and a socket wrench head that must be the exact size that the clamps so you can hammer it. The main purpose here is to get the clutch to be still and really tight! *Si hablas espaņol mandame un email a paqueras@hotmail.com y te mando fotos donde pegarle martillazos. |
So does the clutch have to removed I'm not understanding where on the clutch this has to be done.
You have to remove the pulley. Attached its the CLUTCH DISC.
You must press the little clamps that hold the CLUTCH DISC with the pulley. |
by clutch disc you mean the clutch that is still attached to the supercharger itself?
PM Sent!
Originally Posted by paqueras
(Post 5351241)
PM Sent!
the PM was a picture of my pulley. The instructions are one post before.
