c32 wont stay on after 4 or 5 sec after crank
Old Sep 17, 2012 | 01:00 PM
C32 RENNTECH's Avatar
c32 amg
Hi,
Ive been having problems with my car the esp on the screen turned on. The first code that the car thru was p0221 the tps sensor. Come to find out it was vacumm leaks, so i fixed it and now the esp is off the screen. I also put new plugs and fuel filter on. I could see a diffrence but the car was no where near normal. I hooked it up to the diagnostic tool it said the map sensore was bad. I put a new map sensore on first crank car died the second crank the car idled fine and took the car for a drive but the power wasnt there. Came back turned the car off restarted dies after 4 or 5 sec. I hook it up to the diagnostic tool again no codes but the car is still dying. There was a rotten egg smell that came out of the exhaust the 4 or 5 sec the car runs smelt like clogged cats. So i removed the cats the car still dies after 4 or 5 sec. the car is on. I need help im stuck.
Thank you
Old Sep 17, 2012 | 04:01 PM
loudandheard's Avatar
C32/C55 AMG
Check out this thread, it may be related to the esp issue.
https://mbworld.org/forums/c32-amg-c...happening.html
Old Sep 17, 2012 | 07:03 PM
c32 amg
Hey man thanks for the thread but, my car is doing a little diffrent then those. It wont stay on its not drivable right now i dont know why this is happening. After fixing what i fix it ran fine with the test drive power really wasnt there but drivable. Then after test drive i shut the car off and after that any time i crank it up it slowly start dying. It wont keep an idle.
Old Sep 19, 2012 | 12:57 PM
c32 amg
Any other ideas on what it could be?
