2003 C32 Dealer Replacing Drive Shaft
Old Oct 5, 2012 | 11:17 AM
AMG_Guy's Avatar
CLS55
About how much would this be around?
I'm having the 45-60 vibration and going to bring the car to the dealer on Monday.
Thanks!
Old Oct 5, 2012 | 02:25 PM
loudandheard's Avatar
C32/C55 AMG
Thanks!
More than likely it should be the drive shaft support bearing, but you never know the drive shaft could go bad. Hopefully labor won't be too costly, but you never know with mercedes dealerships.. Parts shouldn't be too bad, but I'm sure the repair kit with the bearing would be cheaper than a whole drive shaft.
I've read that the job with the right tools doesn't take that long, but it's when you get stuck and have to invent new ways to reach bolts or figuring out what tool to use is what will cost you time.
Old Oct 5, 2012 | 03:24 PM
C_DirtyTwo's Avatar
a land yacht.
could be the flex disc.
Old Oct 8, 2012 | 01:16 PM
AMG_Guy's Avatar
CLS55
I've found out that I notice it much more in colder tempertures..
Old Oct 8, 2012 | 03:14 PM
C_DirtyTwo's Avatar
a land yacht.
Id check your flex disc. Its rubber, so cold could affect it. Also, if it gives out while youre driving you could be in serious trouble.
Old Oct 8, 2012 | 03:35 PM
Shaus Motorspor's Avatar
mercedes
id say to ur best at a diy and if nothing else take it to a shop
