C32 IAT prblem
C32 IAT prblem
Under full load there is sudden jerk and compressor goes off for a few seconds CEL comes on.
The stored code refers to Intake Air Temperature sensor. It has nothing to do with IC pump as made a test ride and monitored IAT - never goes adove 52DGC
It is also strange that the code it throws says it' unknown failure. Usually when it comes to simple sensor failure it's commonly open circuit or short and it's defined by the STAR, but not in this case.
Anyone seen it before?
MBworld Guru
white and whiter
First time seeing this. I would assume You need this part
http://www.rmeuropean.com/Part-Numbe..._10832E0B.aspx
