SC Pulley BOLT Breaks! HELP!!
Old Nov 5, 2012 | 09:51 PM
paqueras's Avatar
G320 CDI, C32 AMG Sportcoupe, GLK300 4MATIC
HELP!!!
The bolt that adjust the SC Pulley broke!
Anyone had the specifications of the bolt and the grade?
Also if i find a replace bolt...MUST be hollow?
Also someone could help me with the CONVERSION OF 20NM to FOOT/POUNDS? (Possible answer 14?)
Old Nov 6, 2012 | 12:54 AM
macbryanie's Avatar
Porsche 2004 911
"Replaced my s/c bolt. M8 x 1.25 x 25 is the correct bolt dimensions. Regarding the 3mm hollow it’s not due to reasoning of expelling s/c oil. The assembly (where the thread is) is solid so no oil can be channelled via this route. Bolts are also hollowed to reduce weight (race bikes) but this obviously doesn’t apply to this application. So it is safe to assume it is simply a safe guard for over torqueing the bolt (20mn) thus avoiding further damage"
https://mbworld.org/forums/c32-amg-c...lley-bolt.html
Old Nov 6, 2012 | 01:30 PM
paqueras's Avatar
Thank you!
If anyone have the same problem i found those bolts for about USD 0.12 each.
M8 1.25mm x 25mm
Old Nov 10, 2012 | 05:51 PM
C350_Coupe's Avatar
C350 Coupe (CL203)
Originally Posted by paqueras
<snip>
20nm = 14.75 lbft
http://www.boltscience.com/pages/convert.htm
