Need new sway bar bushings, where to buy?
Old Dec 15, 2012 | 02:03 AM
kent426's Avatar
2005 C55, 2006 Ram 2500 MegaCab diesel, sold 2001 Dodge 2500 Cummins, sold 87 190e-16v, sold 97 e420
I went to the dealer and they can only sell the entire bar for $280. I just need to polyurethane bushings, will use stuck rubber if I have to.
Old Dec 15, 2012 | 02:57 AM
cm60k's Avatar
There’re "2" types of Sway bar rubber bushings,
1) 2 pieces 23mm #: "203 323 25 85", mounted with bracket
2) 4 pieces #: "203 327 00 90", mounted without bracket
Which bushings you need to replaced....??
Why that dealer doesn’t sell those rubbers individually.....!!?
ZAYED,,
Old Dec 18, 2012 | 05:44 PM
Tump43's Avatar
2014 E350 4Matic
Just bought two 26 mm polyurethane bushings to use on my C55's new H&R front sway bar at: http://www.googleadservices.com/page...nsionParts.com
they were $18.50 shipped with "universal" brackets. Since these are universal bushings, I hope they fit the OE brackets without the need for too much modification.
Old Dec 18, 2012 | 05:55 PM
Tump43's Avatar
2014 E350 4Matic
Duplicate
Old Dec 18, 2012 | 07:49 PM
WaveyKat's Avatar
Something Slow
Can you take pictures of those poly bushings ? Please I normally would order replacements h&r bushings from evosport.
Old Dec 19, 2012 | 01:10 AM
ruben65's Avatar
Were you having any steering symptoms or issues?
Please post a picture of your worn sway bar bushings prior to removal off sway bar and after removal. Would be interesting to see what failed ones look like.
Old Dec 19, 2012 | 02:23 PM
Tump43's Avatar
2014 E350 4Matic
No I am just upgrading to thicker sway bars front and rear to match my other modifications. My current front sway has a worn bushing that makes a popping sound at low speed when cutting the wheel really far to the left or right while parking. Otherwise, all is fine. I'll see if I can get a picuture of the worn OE bushing. The bushings on the H&R bar are worn so I might as well replace them before installing the bar.
Waveykat, you can find pictures of the poly bushings at the web site I posted previously. I may have to order from evosport, not thinking clearly, apparently.
Old Dec 24, 2012 | 01:29 AM
kent426's Avatar
ZAYED,,
I thought our cars had a 22mm sway bar from the factory. The front links that mount to the frame are shot and the dealer only lists the entire bar.
