C30 cdi AMG
I'm new here and i'm wondering how many C30 CDI AMG owners there are here. I bought a c30 facelift model and want to know the experience of other c30 owners.
I also want to know weather the original suspension can me improved by Bilstein B8 suspension. Has anyone has this suspension on his c amg?
Here's a picture of mine
The C 32 AMG scaled back down to a 3.2-litre V6 engine, to match the E46 M3 displacement and improve weight distribution, but it required a twin-screw type supercharger (manufactured by IHI) to reach 260 kW (354 PS) and 450 N·m (332 lb·ft). Like its predecessors, it used a five-speed automatic, helping it to complete a 0 to 100 km/h (0 to 62 mph) sprint within 5.2 seconds. The second version was C 30 CDI AMG, using a 3.0-litre five-cylinder diesel engine, capable of 170 kW (231 PS) and 540 N·m (398 lb·ft). Both were available in all three body styles, but the diesel model did not reach sales expectations and was retired in 2004, as was as the C 32 AMG SportCoupé.
Source:
http://en.wikipedia.org/wiki/Mercedes-Benz_C-Class
If you have the standard sedan (W203) then the world is your oyster when it comes to suspension and brake upgrades. All W203's without the 4matic driveline can use the Bilstein PSS9 coil-overs.
And according to Bilstein directly the shock absorber for your car is indeed the B8. Specifically
Front: 35-053453
Rear: 24-068819
Source:
http://web1.carparts-cat.com/default...E018004&12=140
it really goes as hell!
i also want to upgrade the breaks to the SLK 55 amg breaks. Normally this works without big changes. just have to find them
Front: 35-053453
Rear: 24-068819
Source:
How does the PSS9 drives?
If the car has done less than 125 000 kilometers then I would suggest that you take it to a tuning shop for ECU programming. I have two friend who are running about 300 BHP and 600 HM of torque. Their cars were between 100k and 125k when the ECU programming was done and have been running for more than 100k after that with no special problems.
If you want to do ECU tuning for your car I can recommend couple of places in Finland since it is the holy land of diesel tuning.
I think its worth the money for that feature and if your roads aren't the best then I'd highly recommend it.
BTW you should put the "C30" back on the trunk! From the factory does it read C30CDi on the left and then ///AMG on the right?
Now i sometimes get the remark that a AMG badge may only be placed on a real AMG and that mines isn't a real one...
What do your brakes look like? Same setup with 4 piston fronts crossdrilled. And 2 piston rears?
In Germany you find a lot of c30 SC. i don't like them like a sedan or wagon. i first searched a wagon facelift but that was no go... i'm glad i found this one, nice option and facelift!
YouTube: - (1:28 to 1:36)
http://www.youtube.com/watch?NR=1&v=...ture=endscreen
