C32 fuel pump finally died.. Part No.?
Old Dec 27, 2012 | 07:16 AM
johnng117's Avatar
2002 C32 AMG
My fuel pump died today, been searching the web for the correct part no.
It been hard to identify a single correct part no. Im coming up with lots of different ones, anyone with the correct one?
Thanks.
Old Dec 27, 2012 | 08:15 AM
WaveyKat's Avatar
Something Slow
wow that sucks thats a 800+ part. just remember thattbhe C32 right side Pump is a Dual Pump. "two pumps in one"
EPC shows..A 203-470-34-94
Look at post #12
https://mbworld.org/forums/c32-amg-c...low-rates.html
Or Here:
http://hibruce.pixnet.net/blog/post/24960412
Old Dec 27, 2012 | 04:05 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
If you buy from the Stealership, yes, it will be $800 for the whole fuel tank and pumps. But you can access it from under the back seats and source out the pumps here for much cheaper.
The main fuel pump can be purchased here:
http://seekpart24.com/pierburg/fuel-pump-722013020?c=100717&at=11221
And the fuel sending pump can be found here:
http://www.ebay.com/itm/New-Volkswagen-FUEL-PUMP-Passat-Jetta-Fox-Golf-Scirocco-oem-PIERBURG-357906092C-/150969632901?pt=Motors_Car_Truck_Parts_Accessories &hash=item23267dc885&vxp=mtr
Good luck!
Old Dec 27, 2012 | 08:45 PM
johnng117's Avatar
2002 C32 AMG
Thanks for the help, much appreciated.
I will proceed with purchasing the pumps and shaping out the pumps only.
Let you know how it goes.
Thanks..
Old Dec 28, 2012 | 08:47 AM
WaveyKat's Avatar
Something Slow
ok kool post some pictures :-)
Old Oct 10, 2020 | 09:03 PM
gobiz's Avatar
2002 C32 AMG
Greetings,
So im having the same long crank problem with my c32, and the car has had the full spark side replaced and also the fuel filter.
I'm quite sure it's the fuel pump now.
I see that Bosch has the full assembly with 2 pumps, part no 0986 580 184.
Has anyone used this full assembly ? I would rather replace the whole thing rather than pulling out the fuel pump.
Thanks in advance
Bosch 0986 580 184
Old Feb 22, 2021 | 01:59 PM
Mohbaki's Avatar
W126
Any update on your experience with the BOSCH fuel pump
Originally Posted by gobiz
Greetings,
Thanks in advance
Bosch 0986 580 184
I would be interested to know your experience with replacing the fuel pump as I need one for my C55 2006
appreciate any feedback.
