Has anyone had to replace their balance shaft?
My mechanic tells me that the gear at the end of the balance shaft cannot be replaced without replacing the whole balance shaft. To do this you have to remove the engine from the car because there are bolts securing the balance shaft between the engine and the transmission.
So basically, this is going to cost me a _LOT_ of money.
Has anyone had this issue? Is this the only way to fix it?
...also, to add insult to injury, the car is only driven 134,000 km (83,000 miles)
I'll swing by the shop later and see if I can get a picture. I'll also find out which code came up during diagnostics.
