is it normal?
Old Aug 26, 2003 | 06:10 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Question is it normal?
sometimes when I'm on the freeway I get this occational opening where I can just floor the gas pedal. I found out that if I floor the gas, but don't depress the kickdown buttom it only downshift to 4th and it doesn't even try to redline when shifting to 5th. When I depress the kickdown buttom it downshifts to third and redline through each gear. This is going around 80-85mph when I floored it.
just wondering if the same case happened to you guys, or is it just mine.
Old Aug 26, 2003 | 07:19 AM
cobraq8's Avatar
02' C32 AMG
For some reason, my car seems to downshift to the lowest possible gear whenever I floor it (without pressing the kickdown). I noticed this because everytime it downshifts, I then press the kickdown immediatly, however, no change occures.
Old Aug 26, 2003 | 07:25 AM
cobraq8's Avatar
02' C32 AMG
Old Aug 26, 2003 | 11:16 PM
DL_AMG's Avatar
2011 C63, 2004 S500, 2013 E350, 2013 Ody Elite
Auto tanny
always have mine of its own. That's why you have Speedshift on your right hand.
Old Aug 27, 2003 | 05:32 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
yeah, I use speedshift a lot, just not in those "no other car" situation. lol
Old Aug 27, 2003 | 04:06 PM
eyuan23's Avatar
asdf
Re: Auto tanny
Maybe you weren't hitting the throttle as hard in 4th so the auto tranny decided to switch gears prematurely. I would just tap the speedshift 2 gears down (assuming you are in 5th) and ride it all the way to redline (which it should do). Or use the kickdown and let the tranny decide the lowest gear to use.
