Power Steering Cooler Leak
Old May 17, 2013 | 08:00 PM
biglos's Avatar
2005 C55
My C55 just developed a noise coming from the power steering system. Upon investigation, I found that the fluid was low and there is fluid in the area of the cooler for the power steering system.
Has anyone changed the cooler? At this point, I am just thinking that the seals where the hose connects to the cooler failed. I have been searching for parts but I have not found a drawing or parts breakdown what could have failed. I can only find the cooler or the hose. Does anyone have experience changing the cooler or the hose supplying the cooler? Thank you in advance.
Old May 18, 2013 | 01:14 PM
JonMBZ's Avatar
06 C55, 09 E350
Here you go.
Old May 20, 2013 | 11:48 AM
biglos's Avatar
2005 C55
TY.
I just started disassembly and my system is slightly different than that. My system has 3 small coolers. 1 on drivers side, 2 on passenger side. There are 2 small o-rings that provide the seal and 1 o-ring failed.
