Miss at idle Dealer says MIGHT be #5 injector 1200$!
Old May 17, 2013 | 08:53 PM
RKturbo6's Avatar
2006 Capri Blue C55 AMG
Well not sure where to go with this. light to moderate miss at idle. Very recently changed plugs and magnacore wires. Was thinking MAF but no CE light so not sure. Took to dealer and they said they THINK it could be the #5 injector. Can not be cleaned and needs to be replaced. 560$ for part and 600 for labor! RUKM?! And cannot be sure that is the issue. Soooooo kind of at a loss on what to do. Know I need a new Air pump as it makes a ton of noise sometimes but looks like that is just for emissions and would not cause miss. So any ideas? Thinking about replacing MAF sensor and maybe just getting another injector (for much much less than dealer) and replacing it myself.
Any help here would be greatly appreciated.
Old May 17, 2013 | 10:32 PM
Zeppelin's Avatar
C32
If it were me as I could do it myself - I would swap the #5 injector with another cylinder and see if the problem switches cylinders.
Old May 19, 2013 | 11:13 PM
ricecooker713's Avatar
C63 E63
^ with him
Old May 20, 2013 | 08:09 AM
absent's Avatar
GT63S ePerformance 4dr, '25 Bentayga Black Ed.(wife), Wrangler and 250 MLB(kids)
Problem appeared AFTER you put in new spark plugs?
Could be a faulty plug,effect would be similar to dirty injector.
Replace the plug at that cylinder and see what happens,quick and easy test....
Old May 20, 2013 | 06:22 PM
macbryanie's Avatar
Porsche 2004 911
If it is the injectors and the p/n # is the same replace the lot at $20 each. I purchased through the below about a month ago.
https://mbworld.org/forums/engine-pe...156-072-a.html
Old May 21, 2013 | 12:35 AM
c32kompressor's Avatar
CLK55 AMG
PM me if you need injectors. I have 5 oem M112k injectors, the sixth one is on my C32 . but i can work something out with you on the low
Old May 21, 2013 | 01:50 AM
benz_addict's Avatar
V12TT
This whole job can be done under $50 and probably 2 hours of your time depending on how skilled you are. GL
