C55 Radio: powers on, no sound. solution
This has probably been posted before but I just had to reset mine again and thought I'd repost for others. I have the standard radio with no command and twice my radio has gone "dead" with no sound. Unit powers up and responds, just no sound.
Solution: turn off the car and remove keys. Go into the driver's side firewall fuse box and pull fuse #64 then replace. It should be a blue 15 amp fuse on bottom of the first row closest to the firewall. Your radio should work with sound again.
Regards,
Regards,
ODB (07-20-2018)
SOLD - 2005 C55
Hey Aaron,
Thanks for the tip. When I first encountered, I was so pissed-off! I ran out to listedn to the radio as my music was about to come - ok, old fashion but I don't have BT/MP3 or anything as I, too, standard - and... no sound... at all...
I've had this twice in 1 yr, and no idea what triggers off/on.
Rick
Rick
Hey Aaron,
Rick
Rick
Glad it was helpful!
2007 E350 4 Matic Silver/Ash and 2005 C55 Black/Black
New issue after removing and returing fuse
Hello,
I had done this in the past and it worked fine. This time however, my car won't even turn over I did remove the large orange fuse and the purple "box" relay/fuse? to gain better access to the blue fuse in the back.. Everything came out and was put in fine Any ideas on what I may have done to have caused my car to now not start or even have the Fob lock the doors?
