acceptable iat range C32 AMG
c32 amg
what is the acceptable range for IAT? My 202 C32's temp gauge shows the temp in celcius and is in the middle of 80 to 160 range which means about 120 degrees Selsius. this translates to abut 248 Farenheit. is this acceptable IAT temparature for summer (in DC area) or is it running too hot? Thanks,
andy T
andy T
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
andy T
andy T
2002 W203 C32 AMG / 1997 Toyota Corolla AE110
i have done the coolant isolation mod, CM30 pump and Frozenboost Heat exchanger installation.
Ambient temperature is around 30-33C here. And the IAT is about 42-45C in highway cruising. 65-67C in full throttle 0.8bar boost.
My car has separated cooling, bigger heat exchanger and stock (newer version) bosch pump. Running from 0 - 230 km /h (0 - 143 mph) results IAT being about 70 degrees C (158 F). Ambient temperature being 20 C (68 F).
Also running 65 mm SC pulley, ECU tune and NW intake.
Here are few logged runs:
http://kotinet.com/mortem/mittauksia_01.PNG
http://kotinet.com/mortem/mittauksia_02.PNG
http://kotinet.com/mortem/mittauksia_03.PNG
C280 Merzedez Benz
I need help, I drove my car to the Nearest mall last week, and when I came back after 20 minutes shopping, it could not start. It was towed to the nearest dealer, and after 3 days they tell me the car key lock has stopped functioning, and its a known issue with merzedez benz
has anyone had this experiece before
