HELP!! C32 QUESTION
Old Sep 6, 2013 | 07:47 PM
ssoutlaw74's Avatar
2003 c32 amg
HELP!! C32 QUESTION
Ok can someone help me out? Wife was driving car today all was fine
she went to pull away from stop and NO power ! there are no codes
on dash .anyone had this problem? supercharger pully mabe?
Old Sep 6, 2013 | 10:09 PM
ssoutlaw74's Avatar
2003 c32 amg
So i cycled the key a few times and its ok now wtf mabe trans was stuck in high
Old Sep 7, 2013 | 03:35 AM
firstshadow's Avatar
03 C32 AMG
Sounds like the intercooler pump is failing which causes temporary power loss.
Old Sep 7, 2013 | 08:53 AM
saer1one's Avatar
2002 c32 AMG 2012 c250 Coupe
Intercooler pump is out.. Reason why it worked when you cycled it was because your AIT's cooled down but it will continue to shut down your supercharger when AIT's increase for safety reasons.. With the engine off turn the key to the position 2, walk over to the front passenger side of the front bumper, listen underneath the car and you should be able to hear the pump running, if not then you need to replace the pump.. Do a search on bad IC pump and you will find great advice on how to better trouble shoot and replace a bad IC pump..
Old Sep 7, 2013 | 09:02 AM
JamesC32's Avatar
2003 C32 AMG, 2015 RAM 1500 4x4, 2012 Merc GL450
Also the gas peddle can go out, I guess when mine went out the sensor in it maybe would heat up, I would give it gas and nothing just would barely idle, if I turned the key off and started it back up it would work again for 20-30 min or so then do it again, and then it got worst.
Old Oct 8, 2013 | 10:06 AM
ssoutlaw74's Avatar
2003 c32 amg
Pump was out thank you for help and wow does it run now! I love this car!!!!!
