coolant flush question
Old Sep 11, 2013 | 11:29 AM
bdougert1220's Avatar
2005 c55
Hey guys so last week i picked up a 05 c55 with 89k mi. So im just getting my fluids up to date, did oil change with mobil one and oem fiter, now i want to do a coolant flush because its green not sure if they even did it rite or when it was done last. So i got 3 gallons of the correct coolant. Ive did plenty of searching but get different results every time. Should i drain the res and rad. Then fill it up and run it with heat on high and repeat this like 3 times? Will this dilute it enough?
Thanks.
Old Sep 11, 2013 | 03:31 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
Mine is green too only cause my mechanic put in a dye to help diagnose leaks.
Old Sep 11, 2013 | 03:44 PM
2005 c55
Yeah but do you think i should flush the coolant that way?
