c32 AMG died after MAP sensor change!! PLEASE HELP!!
U start the engine and itll seem like its going to catch for a slit second nd run at idle normally but it just dies instead. So I took everything apart down to the map to make sure I reinstalled it correctly and still Nothing. It won't start. Wont run.. to get to the map I took off my tps. I thought that might b part of the problem so I thought id try disconnecting it. When I started it with the tps sensor unplugged amd it actually started but it woukd idle like a maniak between 500 and 2000 rpm... tried doing the tps reset by holding the peddle down for 5 seconds with the ignition on about 3 times and it sounded like it reset but without ever fixing my problem.. I ended up abandoning it at my buddies shop because I couldn't make it run.. any ideas would be greatly appreciated.. im thinking either napa gave me the wrong map sensor or my tps started going crazy after I took it off and put it vack on. My current mods are as follows; new radiator, new supercharger intercooler pump, needwings belt wrap kit, supercharger pulley upgrade, engine and transmission tune, new plugs, filters and fluids. Shes got 130,000atm.. I live in the middle of nowhere in alaska and the only dealership in the state is 300 miles away so with the car in its current condition, no I cannot just take it to the dealers/: thank you greatly for any advice..
