Help C32 does not start
Now after 2 weeks I have the same problem again but no codes are stored. I just checked fuel pressure and came back with around 55 PSI while cranking, so I don't think it's a fuel starvation issue. I have ordered a new CPS and will be replacing it but am not sure if that will solve the issue. I think CPS usually fails when hot and engine does not fire at all. My issue is when the car is cold and it does try to fire up just does not stay started.
Don't know what else to look for and need help on troubleshooting. Any advise is greatly appricaited.
I had this fuse blow on my C32 and the engine would crank but would never start because the fuse was blown.
Check to see if this fuse is in tact!! It will cause a no start condition similar to what you are experiencing
