Help required please................
I now just want to lower the car some more but i had a problem at the front with the inside of the tyres rubbing on the strut, i require to get some 10mm Hubcentric spacers from H&R,.
Does anyone on here have them fitted to their C32 and if so what size of bolts did you have to order to fit them safely?
Any help would be much appreciated.
Here's a pic of my c32 AMG Wagon as it is, before i can lower it anymore without the rubbing issue.
I got the Eibach coilovers from Demon Tweeks in England, they assured me these are a correct fit for the c32 AMG and they also gave me the ones for the correct axle weight to cover for the Wagon. They fit fine it's just i cannot lower the front as much as i would like to because of the rubbing issue, so 10mm spacers will clear the strut and i can lower the front an extra 2 inches. I will look at getting those 49mm shank bolts then and get the spacers ordered.
Hopefully this will all help and i'll be sure to get some pics when she's finally at a height i am happy with.
Many thanks for your help
