Sounds Coming From Suspension on 02 C32
Old Nov 23, 2003 | 03:39 PM
Accomplice8's Avatar
xx
I just picked up an 02 yesterday and drove it 1,200 miles. I noticed that when I'd come off the highway and pull into uneven parking lots at around 5-10 MPH that there is a clunking sound coming from the rear wheels. It sounds a lot like what a flat tire sounds like (not flats present). Is this a normal noise at low speeds? Also, the suspension creeks a lot. It sounds like you can hear the springs compress. Is this normal. And one last noise is when the brakes are depressed at highway speeds you hear what I can only describe as being like very increased road noise (low pitch hum like noise) as the brakes grab. Just wondering if any of this is typical.
Kevin
Old Nov 23, 2003 | 03:44 PM
Harris's Avatar
Re: Sounds Coming From Suspension on 02 C32
Kevin
Not sure about your first noise.
The second noise sounds like the sway bar bushing. It is a very common problem with early generation C32s. Just take it to your dealer and ask them to change the bushings to the '03's.
The third noise sounds like your rear rotors were warped.
Old Nov 23, 2003 | 11:08 PM
AMG BRED's Avatar
CLK63 Black Series
d'oh...
time to lower it :p
Old Nov 23, 2003 | 11:34 PM
xx
Re: Re: Sounds Coming From Suspension on 02 C32
Harris,
Thanks for the info. I'll have the dealer swap out the sway bar bushing(s) for me. How does the dealer treat issues like warped rotors, do they cover that under warranty?
Kevin
Old Nov 23, 2003 | 11:48 PM
Harris's Avatar
Re: Re: Re: Sounds Coming From Suspension on 02 C32
Harris,
Kevin
I dont think the warranty covers warped rotors. FYI, we have the same rear rotors found on the W210 E55.
