C55 Alternator Replacement
So just wanted to say, "Yes" that is the only way. There simply isn't room to drop the alternator out the bottom. Imagine a motor mount and if you haven't done one of those you have no clue. The alternator is twice that. It will be a messy job too because you'll drain your radiator and remove hoses to your overflow tank. It will a tuff tug to get your fan shroud out as well, you need 4 thumbs (I used a feeler gauge on one side in lieu of not having more thumbs). I found the plastic pieces, clips and such, would break with the slightest provocation, dealer parts only too. Be prepared to replace your idler pulley and belt. I got a replacement Alternator from PepBoys for about $177 but you can get them from AutoZone too or likely else where of course this is after you leave your old one which is worth about $75. And YES, it won't come with a pulley so be sure you take the one off your core. I have some receipts laying around if you need p/n
I could have just replaced the regulator on the back of the alternator but to be honest, considering the amount of work involved to R&R I decided not to take the chance the DIODES which cannot be replaced (that I know of) were bad. It was tested and was BAD. So decided to replace the whole thing. I didn't do a write up here thinking someone else already has, if not if you catch me within a few days I still may remember things and might have a picture or two.
I have two words to describe it "PITA" & "MESSY". Plan for about 3 hours tear-down taking your time not to damage things like the radiator. I think I put it back together in about 1.5 hours. Not sure how much I saved by not taking it to the dealer. I read somewhere that the alternator from a dealer was around $600. I assume this was just the part, not labor. Nothing like the feel of antifreeze on your hands too, which reminds me - buy brake fluid cleaner, you'll need it.
To be honest, maybe I'm cheap, but I would do this again now that I know how. And though this may sound weird, it seems to run better. Dyno mode shows 14+ volts, before was up and down somewhere between 12 and 13.5.
Effe and I...................1
Next up, A/C Blower Motor -- it's making a ticking noise so need to see if it is rubbing on something in there.
