air con question
Old Dec 3, 2003 | 03:32 AM
ultraseven's Avatar
C32
Question air con question
All,
Hopefully the symptom I am describing is normal....
My temperature gauge is reading about 57 oF, and I turned the thermostat of both zones to around 75. But alas, for some reason, the middle vents (especially the one on the passenger side), blow out cold breeze while the far left and right vents blow out warm air. This is the case with either AUTO on or off.
Is this normal?
Old Dec 3, 2003 | 09:46 AM
dfc's Avatar
dfc
03' C32, 98' Civic EX
Check to see if the little rotating knob between the two center vents is rotated to the bottom. Visually, the blue dashed line indicators only half appearing on the bottom portion. Other than that, also check the center dash vent (the one that looks like a speaker cover on your dash facing up. Just turn it off completely as it serves no purpose.
Old Dec 3, 2003 | 11:33 AM
fly's Avatar
fly
I have the same condition. Visited dealer twice, they said it is normal. MB desiged all center vents to not blow hot air onto your face, according to the dealer. Whenever I need higher temp, I just set the temp adjustment to HI, the center vents would blow warmer air.
Old Dec 3, 2003 | 02:14 PM
hammyoni's Avatar
C32
really? in colder climates it does serve a purpose and a very good one at that. defrosting the front windows is a good feature in my view. i have that same problem with the middle vents its annoying because its freezing outside but the middle ones are cold air. The car still gets warm though.
Old Dec 4, 2003 | 02:46 PM
moomeh
Guest
Posts: n/a
it has a purpose..... leaving a thick residue on the windshield that you have to clean off or else you get this glare.
Old Dec 4, 2003 | 04:24 PM
Bux's Avatar
Bux
G
OT - but is there a way to shutoff the fan speed to OFF by holding down a button? or do you just have to tap the lower speed thing 50times? ...i thought i did it loooong time ago
