Which Walbro pump for C32?
Old Jun 28, 2014 | 05:39 PM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
Originally Posted by raf12690
Bump for updates. Hows the car running so far?
The car is running super. Took a 150 mile drive today to Avalon NJ. The fuel pressure is hovering around 60 psi and the AFR is just right. Didn't get to the fuel line changes yet but will complete it for sure as soon as I get some time on the lift.
Old Jul 1, 2014 | 07:04 AM
raf12690's Avatar
c32 amg
Nice! I wonder if when all is said and done you end up with similar HP numbers as the SLK. Keep us updated!
Old Jul 1, 2014 | 07:05 AM
raf12690's Avatar
c32 amg
Btw are you running 178/65 or 181/65?
Old Jul 1, 2014 | 07:51 AM
Lenin's Avatar
I'm not a big believer in dyno HP number. I only use dyno numbers for tuning. Track numbers are more important. My previous best 1/4 mile was 12.42 secs.
I'm currently running a 164/65 but also have 62mm SC and 181mm crank and will be trying different combinations later.
Old Jul 2, 2014 | 08:16 AM
raf12690's Avatar
c32 amg
Nice haven't heard much of the 164 crank. Definitely keep us updated. Im currently running just the code3, but have my 61 sitting in the garage, might look to stack in the future seeing as more fueling options are out there.
Old Jul 2, 2014 | 09:06 AM
Lenin's Avatar
164 mm crank pulley was a one-off custom pulley I got from ASP http://autospecialties.com A customer canceled their order and I picked it up at a discount. It is 10mm larger than OEM and while I was looking for a 168mm crank pulley, 164/62 should be just fine.
Old Jul 2, 2014 | 09:25 AM
  #32
scboost's Avatar
b5 a4
Lenin do you know how much you paid for that pulley. Asp is literally 10 miles from my house and I am thinking about calling them and trying to work a deal as i don't see these flying off the shelves anymore lol
Old Jul 2, 2014 | 09:53 AM
  #33
Lenin's Avatar
I don't recall exactly and don't have my records since I'm still away from home at the beach but it was above $650. I got lucky since a mistake regarding the size was made and that is why the customer canceled their order. These pulleys are made to order using OEM MB pulleys and the fact that they are not flying of the shelves may not have any impact on the price. I do recommend calling the place or since you are so close, just stop by. Often vendors in person are a lot more agreeable.
Old Aug 29, 2014 | 11:10 AM
  #34
Lenin's Avatar
Update. Project is completed.
Finally completed this project. First phase was just changing from OEM to Walbro 255 pump with 550cc injectors and a looped fuel rail (completed in June). Second phase was to swap for the filter without the regulator, add a check valve, AEM adjustable Fuel Pressure Regulator, run an -8AN fuel line and reuse the existing fuel line as the fuel return line between the FPR and the fuel tank. Did not have access to a car lift and had to spend a lot of time on my back under the car, mostly measuring.
The car runs great. Fuel pressure is set to 63 PSI at this point. AFR starts out at 14.7 at idle and drops to 11.8 or so when shifting from 3-4. Will do more data logging over time and will adjust as needed.
Old Sep 8, 2014 | 08:07 PM
  #35
raf12690's Avatar
c32 amg
How does the acceleration feel? You going to make it to the track this year?
Old Sep 9, 2014 | 07:19 AM
  #36
Lenin's Avatar
Acceleration is strong but it was strong to begin with. The plan is to take the car to the track. My only concern is my axles. I broke it two years in a row. I'm hoping for a 0.1 - 0.2 second difference in a 1/4 mile run.
Old Sep 17, 2014 | 03:34 PM
  #37
raf12690's Avatar
c32 amg
Good stuff. Definitely let us know when you get that beast to the track. I'd be more interested in seeing the trap speed difference than et, but who knows you might just snag that record away from Pansu. Good luck!
