19" VS 18" wheels, please advice...
Old Jun 20, 2014 | 05:33 PM
tim175's Avatar
W212
Hi,
Currently i'm driving an C55 fitted with:
Front: 19x8,5 ET30 235/35-19
Rear: 19x9,5 ET31 255/30-19
With passengers the rears occasionally rub on the outside.
I have seen a set of E63 wheels, but will these fit?
Front: 18x8,5 ET38 245/40-18
Rear: 18x9 ET39 265/35-18
I'm affraid the rears will rub on the inside (I prefer to use no spacers), maybe someone can advice me?!
Old Jun 20, 2014 | 08:07 PM
dsp_tdi's Avatar
2005 C55
For the rear, this will be ok. I have 285 with et40 on 18x9.5 (I just grinding fenders/bumper joint)
265 with et39 no problem (the outer of tire will be at the same place then oem wheel with 255 tires)
probably you are good to put 5mm space without mod.
