Pulley Noise
Old Sep 24, 2014 | 01:06 PM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
Pulley Noise
I had an issue with a squeaking noise coming from the engine bay. I thought for sure it was the loan pulley above the alternator that was installed as make shift belt wrap. I ended up buying the needswings PSK and installed it. All was good for about 3 days and now it is back and worse that ever. I do have a PS leak but I keep it filled up and it makes no difference if it is full or not. The odd thing to me is the timing of the nose. In the morning if it is cool outside it starts with the car and is pretty loud. Then as the car warms up it only happens at about 1200rpm +. After I have been driving and the car is at temp the noise goes away. When I installed the PSK I had a look at all of the pulleys and did not notice a problem with any of them. Any Ideas?
Old Oct 14, 2014 | 10:32 AM
insame1's Avatar
I know this did not get any action but incase it is found in a search it was the water pump.
