Will Stock E55 Injectors Work On A C55?
The ecu thinks it has 283cc injectors so knows just how many milliseconds of duty to give at any particular throttle position, rpm and MAF reading. The ecu is calibrated to the 283cc injector. You have 396/283= 1.4x larger injectors so the engine will be receiving approximately 40% more fuel than was intended. This will wash the oil film from the cylinder walls causing scoring, it will foul the spark plugs, it will ruin the cats and also the oxygen sensors. Power will be much reduced.
Some of this effect can be tuned out by adjusting the fuel tables but I don't know if it could compensate for the extreme difference. I know the supercharged guys have a lot of trouble with adjusting the resolution of the stock MAF. Even so, no one is wanting to spend heaps of money on tuning to get back to where they were before.
The other thing to consider is that most OEM applications have significant head room as far as injectors go. They usually only run somewhere around 60-80% of maximum fuel flow rate when the engine is making full power. This means that there is still a lot of scope for increasing power without needing new injectors. This is more than enough for headers, intake, port/polishing, cams, ecu tuning, almost anything on an NA engine. Of course when you increase your volumetric efficiency 50-100% with turbos or superchargers then that head room, is instantly gone and 400cc and larger sized injectors are needed.
The reason that I am not using my old injectors is because I do not trust them. I changed the filter baskets which were not supposed to be changed (I had to mod the edges of the universal baskets because they did not fit). I also cleaned them the wrong way and used carb cleaner with the filter basket out. I learned from my mistake.
c32,c43,e55,cl55, clk55,s55 amg are all the same injectors and same tunes/computers as well. The size is 25 lb/hr !!
same goes for the e500,e430,s430,s500,cl500,sl500 these are the same ecu and all use 20.5 lb/hr injectors
i tune these ecu’s
If I want to swap injectors for my c43 w202, I was told injectors from a w208 clk430 would work. Is that not correct?
Same goes for the e55/c55/s55,clk55 use the same computers, cams and injectors in theirs
