C55: Weakest Link
But, I can't seem to find much of anything about the rest of the drivetrain. I guess because of the rarity and being a luxury car(thus less people modifying them) the number of guys pushing even 1.5x the stock power I could probably count on 2 hands. Even the number of full bolt on guys is pretty slim. As such, there doesn't seem to be much in the way of what goes when. It vaguely sounds like the half shafts are most likely to go 1st. The diff and driveshaft though, I found basically nothing. So out of the engine, trans, driveshaft, diff, and axles, what's the order of strength? Or is it the little details like U-joints that are the most likely culprit?
Also, although there is more to it then simply power, what is the actual torque rating of the C55's 722 trans? I got tons of the "they all are 796lb-ft, per the V12's" some info saying there is a 550lb-ft and 796lb-ft version, and also Chrysler/Dodge's version, the W5A580, officially being good for 428lb-ft(580nm=428lb-ft). Thanks in advance!
If you want a strong V8/Auto combo to make some big power with, the C55 NA V8 5.5 is not the one to start with. Mods are limited, and making them work is expensive. Step up to an E55 instead with the V8 Kompressor; power is much more easily had with that stock setup.
1)trans
2)motor
3)driveshaft
4)diff
5)axles
The trans/engine are rock solid, the driveshaft I don't hear much about, but just due to sudden impact or wheel hop, the axles and then diff would seem most likely to break, as in most cars.
