Weird C32 security feature?
Lately, or perhaps since I got the car, I notice that after you started the car, and turn key to position 1, the power seems to be stay on for like 10seconds or so, then it cuts the power to command, dash lighting, and the MFD (best way to describe is like someone or something cuts the battery cable 10seconds after you turn the key from pos2 to pos1. When I tried to start the engine from pos1, it will not do anything (meaning it doesn't do jack sh*t), not matter how to turn the key back and forth. HOWEVER, if I take the key out and put it back in, it starts like normal, I always thought this is some sort of MB security, until my friend was in the car when it happened, and he said this is not normal.
The good thing is, at least I know I way to get around it to drive it everyday, but I want to know on earth is going on this thing.
This problem is very consistent, it does it every time when I shut off the engine by turning key from pos2 to pos1, and 10 secs later......power cutoff? I tried to google and doesn't seems to find anything, I searched at EIS too, but no luck............any ideas?
one last thing, for a car that is from 2003 with 65,000miles, the heated seats buttons seems a bit "loose", is there something wrong or i need some beer to chill out?
