2003 c32 rear diff troubles
Hey guys, my diff has gone out in 03 c32. I went to a local junkyard that I found on car-part.com and bought a diff. Looks exactly the same, but when I get home, I can't get the axles in all the way. There is still like an inch of axles shaft biw going into the diff. Could this be a 2002 diff? Are 2002 axles shorter since they are Clip on??
Yea im doing the work myself. I don't know what part numbers to check as there are a bunch of them. The case numbers match. But many cars use that same case. I opened the diff up and got the number on the gear but I couldn't find anything. Its like the axles just won't go in anymore. Doesn't make sense to me.
Anyways. Go to drive and bam P0720. Wrong gear ratio. Wrong diff. The cover was the same part number... Any ideas what kind of diff this could be?? What other diff's bolt into a c32. I'm thinking about getting towed to Euro charged and see if jerry can just reprogram my TCU.
Any ideas. Plz Lenin I needz halpz
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
Maybe now is the time to get on the Quaife LSD group buy.
The ratio for the C32 is 1:3.06. You might have gotten the 3.27 diff. The cover should have A2103513008. But as you know that is used on a bunch of cars. The gear set should be A2203502939. What part numbers do you see?
Lenin the part number on the housing was 2203510105
hmmmm. how did it even fit and work. the parts websites show w203 cars??
http://www.mbpartsworld.com/p/__/HOU...203510405.html
