COMAND Won't turn on after Engineering mode
After installing my "timeset" feature was inoperable under SYS and I could not set my time to match GPS as it was defaulted to the Midwest Timezone for some reason.
So I attempted to see if I could reset it in the engineering mode and well that did not go so well.
I ended up in a screen resolution screen where it showed the color gradient from black to white and I couldn't figure out how to get out of there. I pressed some button (I think it was the mute button) and it shut the COMAND down and now will no longer turn on.
Besides being a retard does anyone have any fix ideas or experience with this?
I also ask that you keep the negative criticism to a minimum as I already am well aware and frankly it helps no one. Plus I just spend $900 on this so I am already a little peeved.
Thanks!
Thanks!
https://mbworld.org/forums/c-class-w...2005-w203.html
Yes - This is plug and play (minus installing camera) with G unit. TMK.
NICE upgrade Maverik...now having it in the family hauler...I now look to COMAND for it in reverse!
But ya the camera still worked like a charm. Didn't have to change any of the wiring or anythhing. Just ripped it and threw the G-Class one in. only to realize i left my Nav disc in my other one, so after fixing all that i put it all back together and has worked great since.
