Data logging
Old Feb 22, 2016 | 09:05 AM
Morphh's Avatar
C32 amg
Data logging
Did some data logging yesterday, 4c outside iat was 16c, 3rd gear pull hit 232kpa or 19.12 psi boost, I'm at 182 feet above sealevel, I run 64.7 mm sc pulley with ec tune and needswing intake. It might help out some pple. Also wondering if anyone has had p0108 map sensor to high code cause of over boost?
Old Feb 22, 2016 | 12:26 PM
Kostas20's Avatar
2003 C32 AMG
Last data log I did was 10c out, iat was 30c, 2nd gear pull hit about 9psi, I am about 3400 feet above sealevel. All stock.
I thought my boost was a bit low after seeing others boost levels on here, but does my elevation reduce my boost?
Old Feb 22, 2016 | 02:20 PM
Morphh's Avatar
C32 amg
It would reduce ur boost but that does seem low, but considering the high altitude it might be right
