Tips for replacing C55 drivers side rear spark plug?
Bueller??
Naugamanator;>
How'd you get the ignition cables off? Trusty spanner method or you have the actual tool for the job?
First put on the sparkplug socket, then extension and finally ratchet.
Loosen it, take away ratchet, keep extension and socket, use fingers to screw it as long as you can.
take away extension, screw with fingers on the socket to get the rest done.
I use an extension that is about 2" long.
works just fine!
works just fine!
Khan - I have the MB spark plug socket removal tool, and a 12mm open end wrench works nicely on the coil end of the wires.
Best regards
