Rubber Door strip
E63 SL55 996TT C5Z06
Morph - hey man. after you pulled off those lower front door rubber weather strips ( or what ever they're called) could you re-use them when you put them back on or did you have to buy a new replacement?
I have rust spots on my lower driver door and passenger door and need to pull that rubber strip off to sand off the rust and then paint over (doing myself) and was wondering what was involved with removing and reinstalling that weather strip.
...Looks like these are the replacement rubber weatherstrip parts??? even if i have to replace with new they arent too expensive.
http://www.mboemparts.com/auto-parts...ber=2036907482
Hope that helps diagram #4 moulding
Once heated up pull from the one end u can grab keep gentley pulling it right off don't push it back on other wise it will bend moulding wrong way it will kink
