61mm pulley major slip
Recently installed my eurocharged 61mm pulley with a new stock belt, drove it for about 2 weeks with no problems. Nooow the tensioner is chattering and the belt slips at hard throttle almost as if the car is shutting off and on(a day ago at hard throttle my belt slipped completely off all pulleys). The gap between the magnetic clutch and the pulley is on point. The belt is fine, no tears or threads missing.
Could it be tensioner issue?
Need smaller belt?
Sell the car and get a AMG GTs?
What are your thoughts?
How are you liking the new pulley? Were there any issues geting the old one off? Did you upgrade the injectors and get a tune yet?
2.)I love the new pulley it came with a lot more punch than I expected without the tune.
3.)I only had one issue which was the fact that the old pulley was very old and basically welded itself to the rod unfortunately it made me damage the old pulley when I put a puller on the teeth.
4.)injectors will be on down the line....right now I'm focusing on widening the intake and freeing some exhaust so that I can get the tune
Not sure what both kits include at this moment. You should contact these members directly.
