C32 Amg Can Bus communication issue
Old Jun 8, 2016 | 09:54 PM
Supercity95's Avatar
C32 Amg
Hey Mb users so i have been having a problem with this c32 i bought a few months back i was able to get some codes ran and it comes back with a lot of CAN communication Faults ill post the codes for the Tranny unless asked for others because i have 16 pages of codes
Monday, May 16, 2016 Automatic Transmission Codes
P2300 CAN communication is faulty
P2311 CAN Communication Engine System Faulty
P2310 CAN Communication Traction System Faulty
P2312 CAN Fault Communication Engine System/Engine Temperature
P2313 CAN Fault N15/5, Implausible Level Position Electronic Sele -
ctor Module (ESM) -
any and all help is greatly appreciated will also send the file to you if you want just need an email address or some way to get it to you thanks again!
Old Jun 9, 2016 | 08:06 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
have you had your battery load tested?
Old Jun 9, 2016 | 09:25 AM
C32 Amg
I have and i was told its still good but on its last cycle of its life when i run the vehicle and check the Volts in the VDO i get around 14.5 while the vehicle is running and 13.2 when its off unless i have the radio on or other accessories
Old Jun 9, 2016 | 04:05 PM
insame1's Avatar
I was having all kinds of problems. Car was in limp mode, ABS module error and speed sensor among a long list of other codes. I foolishly swapped the conductor plate and still had issues. I then swapped in a new battery and all the other issues went away. In your list of codes are the a bunch of low voltage warnings? My previous battery tested fine on a volt meter but it was definitely bad.
Old Jun 9, 2016 | 04:09 PM
C32 Amg
I only seen two that i noticed one said below 10 and other said below 7 but i had drained the battery on accident before the tests were ran
Old Jun 9, 2016 | 04:15 PM
C32 Amg
Old Apr 13, 2018 | 08:56 PM
Kamui's Avatar
Mercedes Benz W203 AMG MOD,2016 Lexus GSF, 2006 Mercedes Benz E350, 2004 BMW 325i, 2016 Ducatti Mons
Did this issues was ever solved?
I am curious if it was, I have experienced a similar issues except that I was getting O2 sensor codes.
