C55 - AC blows hot Driver's Side, Passenger's side cold
Old Jul 31, 2016 | 06:20 PM
MrVu's Avatar
2005 Granite Gray C55
As title states, I have an issue with my AC system. It has peaked 109* in Sacramento and I am just melting in my car
The driver's side including the rear vents blow hot air while the passenger's front and rear vents blow out cold air.
At first I recharged the lower pressure port using the recommended 134a, it worked for maybe a couple of days... I'm suspecting a leak somewhere perhaps or maybe the AC compressor has gone bad?
Any advice or suggestions would be greatly appreciated!
Old Jul 31, 2016 | 06:34 PM
MrVu's Avatar
Originally Posted by Plutoe
The symptoms you discuss indicate a lack of the proper amount of refrigerant---your best bet is visit a shop that has AC gauges and you will have your answer in five minutes.
PSon't fool around with adding you may have overfilled and damaged the system!!
Thanks for the reply! I hope that may fix the issue, when I first checked the low port pressure with valve guage that came with the recharge kit. It was well below the recommended green indicated area. I havn't checked recently but will definitely take it to a professional.
Old Aug 1, 2016 | 09:57 AM
bridluz's Avatar
2006 C55, 2007 C230, 2008 JEEP Wrangler
another ac issue question....
I have a somewhat similar issue that I cant seem to find help with. Air blows cold except when it rains. Something happens, (I'm guessing obviously something is getting wet) when it rains it blows just warm air, not heat just room temp. Very bad because the windows fog up and it's basically undriveable.
Are there any sensors I could check or relays that anyone knows about that I could check? It seems as though when "something" gets wet the compressor turns off or will not turn on at all if I start the ac when it's raining.
LOVE the car except for this issue.
