Bought a set of 18" C63 rims for the C55 (a bit confused)
Old Aug 24, 2016 | 01:47 PM
KPcompetition's Avatar
08' Mercedes C63
Got a great deal on a set so I went for it! I ordered some custom hubcentric 15mm spacers but some really old posts also said I need new wheel studs. But then others said it will be fine. Not sure what to think. If anyone can clarify I wanna get these on asap!
Old Aug 24, 2016 | 01:57 PM
Morphh's Avatar
C32 amg
I believe 10mm or more u would need new wheel studs
Old Aug 24, 2016 | 03:08 PM
MrMustard's Avatar
C55 AMG
Anything over 8mm spacer requires longer studs.
Rule of thumb - if you can turn the nut 8+ times your fine, if not get longer studs.
Old Aug 24, 2016 | 03:22 PM
08' Mercedes C63
Thanks for that info! I will get some longer studs!
Old Aug 24, 2016 | 04:01 PM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
I think they are referring to the m12 you currently have to the m14 you will need for that wheel.
Old Aug 24, 2016 | 04:58 PM
08' Mercedes C63
When you say m12 and m14 are you referring to the studs? Would it be easiest to go to Mercedes and buy c63 wheel studs?
Old Aug 25, 2016 | 10:58 AM
alboogiee's Avatar
M12 and M14 is the "girth" of the stud, if you purchased OEM W204 C63 wheels the stud holes are larger than the W203 stud holes. Separate issue is the stud length; compensating for the spacer with longer studs would work but you may run into wobble because the holes are bigger than the studs you can use. Also you need to measure for the rear wheels--1 or 2 mm too long and you'll hit the parking brake.
