C55 front camber plate ??
Anyone have a recommendation for front coilover camber plates for the C55? K-Mac's website does not list W203. Are there any other brands that supply camber plates for the C55?
Thanks,
Naugamanator
Thanks,
Naugamanator
SPONSOR
We manufacture simple replacement top strut mounts (no mods) to suit virtually all Mercedes models with strut front suspensions.
Unfortunately the W203 requires major mods to install (otherwise we would be making it). Reason is the OEM top strut mount is encased in an outer steel shroud that is welded inside the strut tower.
Therefore for adjustment of Camber and Caster on the W203 we supply replacement bushings for the 4 front lower arms.
The unique design allows precise single wrench adjustment accurately under load direct on alignment rack (no labour intensive removal each time to change settings). Provides up to 4 times the adjustment range of the inaccurate (one only position) fluted bolts.
Extra feature is they replace the 4 front highest wearing bushes and without the OEM oil and air voids which results in noticeably improved brake and steering response.
Track days - can adjust for extra negative Camber for increased track width and reduced understeer!
For the rear similar kit precise Camber (and extra Toe adjustment to compensate). Along with also a replacement bush kit for the 6 multi link rear arms. Significant improvement to rear end flex - especially when applying power lane changing/overtaking.
Front Camber and Caster #502216K $480
Rear Camber (and extra Toe)
4/04-07 (51mm diameter lower arm/inner bush) #501926J $380
00-03/04 (33mm diameter lower arm/inner bush) #502026H $320
Rear Multi link bushing kit #501528K $480
Delivery $30 one kit or $50 front and rear (average delivery time is 3 to 4 days). We accept Visa, MasterCard or PayPal.
