Does the C32 comes standard with MB blue tinted windows?
691 - BLUE HEAT-INSULATING GLASS ALL-AROUND, GLASS REAR
693 - ALL-ROUND WD-BLUE GLASS,BAND FILTER,REAR WINDOW-ES
So my windows must have the blue tint right? It says heat insulating, I'm wondering how it compares to aftermarket tint.
You can visibly see it (they are not aftermarket tinted), and it is on the VIN sheet as yours are.
I looked in the DIY section, and only found the door panel removal: https://mbworld.org/forums/c-class-w...l-removal.html
Might also be found on the BenzWorld forum.
After the panel is off, remove the window glass by loosening the clamp screws at the bottom of the glass. Then tilt it forward, and lift out of the frame. You may need to loosen the frame from the door. They are pretty much the same for any car.
