FYI: Intercooler circuit pump failure
The difference is on the CL and S class the headlight washer tank is heated so the water is really hot.
This is why I'm sure on these vehciles AMG chose to use the coolant resivor to syphon liquid from if needed.
), however the liquid inside the Headlight/Windshield washer tank is not mixed in the cooling system of the vehicle.Wiedermann
The second reservoir is for the coolant (radiator & supercharger intercoolers).
Does the W203 C-class have the same type of setup with 2 separate reservoirs ?
I was under the impression that the intercooler on the C Class used the water from the windshiled washers reservoir.
YES
[/B][/QUOTE]Just for kicks here is the diagram for the C-Class setup.
Looks like it uses the coolant reservoir as well.
) Washer fluid is held/contained/stored/kept in a separate system/tank/reservoir, etc
.Thanks for the diagram!... hmmm.. my father (<--mechanical engineer) is gonna love this (NOT Vader13 "I.... AM YOUR FATHERRRRRRRRRRRRRRRR! - Star Wars" type)
Wiedermann
Any ideas ? Any thoughts to how this effects intercooler temps ?
So the question still stands... Why does the CL/S Class have the larger low tem cooler (as referenced as 110/10) as well as the smaller aux low temp cooler (as referenced as 110/11) whereas the E and C class only have the smaller aux low temp cooler ?
Wiedermann
You may have been thinking of the Evosport Stage I setup which uses the Windshield reservoir and fluid for the intercooler circuit.
What about "stage AWAY from that!!!"
Evosport stage "One million" or what have you are in soooo much trouble if that is true --or maybe I AM in trouble... --... land of assumptions.... if what Mr Blando said is true:
-Reservoir is no longer used for actual "windshield/headlamp washer" but instead for cooling
-If the Reservoir IS STILL used for actual " windshield/headlamp washer" AND for (auxiliary) cooling, if you "wash" away your washable fluid, YOUR CAR IS TOASTED!!!... lol...
I will watch the experts like Mr xxxx@evosport (I forget his name on the board) tell us if that horrible posibility (]You may have been thinking of the Evosport Stage I setup which uses the Windshield reservoir and fluid for the intercooler circuit. ) is actually true
I am in soooo much trouble...
Wiedermann
http://www.amg-owners-club.org/board...5296#post25296
Our Stage I uses windshield washer reservoir for additional capacity. We use windshield washer fluid as intercooler fluid. Yes, it works. Mild soap/ammonia solution that is used in windshield washer fluid actually helps reduce surface tension and improve cooling. Just like RedLine Water Wetter works in antifreeze.
Now, you can still use your winshield washers. Even if you run it dry, there is still more fluid left in the system than stock AMG setup. BTW, low level warning light comes on when the reservoir is 1/3 full.
Mr vadim@evosport:
Thank you for the details on the configuration that is part of Stage one.
I tried looking for my mom last night though... had you Mr vadim@evosport not clarify this now, I would probably be on a plane right now back to Europe (mom refuses to come to me at this stage
, lol )I am counting that you Mr vadim@evosport will be at the Rosebowl this Saturday May 8th???...
Hope to see you all there
Wiedermann
