04 C32 actual images of MAP sensor under intercooler painful removal
Old Jun 10, 2017 | 07:46 PM
unimoged's Avatar
C43, S500, S320, 280 SEL 4.5
There are a lot diagrams from WIS on the MAP sensor location below the throttle plate in one hell of a place below the intercooler, but no actual step by step and images to remove this tough little bugger for code P0105.
So here you go:
1. Remove air cleaners then You have to remove the 4 bolts holding the throttle plate to the super charger housing. (((( Make sure you shove a rag into the housing and remove it later))))
2. Then you have to remove the plastic vacuum line that has the red snap ring. Circled in green. First you press the 2 black tabs, the red ring is exposed, DO NOT pull on the plastic line, first press in the red ring then slide the line out.
3. Use the space created to get a 1/4 inch extension and a torx socket way deep down to where the sensor is, you can see it in the images. Red arrow.
4. Have a magnet ready. get the bolts out then pop the sensor, taking the connector off is a pain, press its connector release tab against the fuel rail edge and try to separate the sensor with a screw driver from the connector.
Install is reverse this sequence and a big pain in the A#$.
Hopefully the images help, since there are none posted.
Attached Thumbnails 04 C32 actual images of MAP sensor under intercooler painful removal-20170610_185921_resized.jpg   04 C32 actual images of MAP sensor under intercooler painful removal-20170610_185935_resized.jpg   04 C32 actual images of MAP sensor under intercooler painful removal-20170610_192039_resized.jpg
Old Jun 20, 2017 | 04:58 PM
Vette Moto's Avatar
Kleemann C55, C32
Was your old MAP throwing a code?
I replaced mine last year in my quest to fixed my intermittent SC issue. It was a PITA for sure. I had the driver side intake manifold off which made it a bit easier.
Old Jun 20, 2017 | 10:18 PM
super-amg's Avatar
c32 amg
what its the part number??? I want change mine
Old Jun 21, 2017 | 09:28 AM
Vette Moto's Avatar
Kleemann C55, C32
0051537228
Old Jun 21, 2017 | 09:39 AM
Bobbyr5's Avatar
2006 C55 - 2005 C230 - 1998 E36 M3
If you take off the throttle actuator and the left side AMG intake plenum you'er all set. Just make sure you have a new gasket for that plenum.
